mhal8876
@Terry@BMS question installing my Jb4, can i run map2? Got 91 octane, denso spark plugs and mid pipe. And my Intake will be here next week! And i need to purchase the Jb4 App.
Don’t waste time using Comfort mode... Sport mode works best and will get the most out of the JB4.@Regs120 on what mode did you do the WOT Test? did some pull today in Comport mode. didn't try the Sport mode yet!
Ok cool!Don’t waste time using Comfort mode... Sport mode works best and will get the most out of the JB4.![]()
How only way i can do that is at night time! Like what kind of speed we talking about here?Needs to be full throttle!Or get a BMS pedal tuner then you can also be 3/4 throttle.
Mashing the pedal fully on freeway onramps will do. 20-70...ish roll on logs okay.Ok cool!
You’re still barley at 50% pedal input and must not be flooring it for a WOT pull. Have you done any WOT pulls yet? If not the ECU hasn’t even learned to advance timing, etc. and has even more potential for power.
