MerlintheMad
10000 Posts Club!
Brand new GT2 with pristine battery box. (note: the "plug thingie" - inserted in the smaller hole - and the grommet)
Mine, damaged twice, sprayed in between. ("plug thingie" is gone; grommet is dislodged by the impact)Hello, All: I would like to get some indication of how common it is to respray the bottom of the battery box on the Stinger.
This came to my attention this week, when I discovered a piece of dangling foam (an anti corrosion coating, I presume) and got under my car and saw black spray paint with fresh scrapes in it. This indicates a prior "incident" backing over something that scraped the underside of the battery box.
I am theorizing that this occurred prior to delivery, and when Kia inspects prior to delivery, and finds a case of scraping, they spray the scrapes with black paint; I suspect this because I've already learned, this morning, of a second case, but from Australia on a MY19.
(Or, alternatively, in the service shop, some "tech" backed my car over a piece of equipment and scraped the battery box; then sprayed black "Rustoleum" to cover the scrapes. This would mean black paint also used in Aus. The third option in the poll is to determine if other colors of "Rustoleum" might be used, and therefore a shop related "incident", not a production/shipping/prior to delivery "incident. If the latter has also occurred to my car, it means I am unlucky, for starters: and it also means that some damned "tech" damaged my car, did not tell anyone, and also ignored the broken "plug thingie" and dislodged grommet. Damn. Anyway, a poll will help me/us determine if delivery or shop "incidents" are occurring as people are backing up our cars.)
In my case, this happened a second time, obviously, or there would not be shiny, fresh scrapes in the black paint, would there? This second time is probably when the extended "plug thingie" disappeared; because the black spray paint did not cover the area occupied by the "plug thingie", and now it's gone and the original buff paint line is clearly visible where the "plug thingie" is supposed to be.
So, if you would be so kind, please look under there and see what your battery box looks like and indicate the results in the attached poll. Thanks much!
