robz32
Texas Stinger Swarm
unfortunately they have not released an oil filter for the 3.3 yet.
The dealership will have the oil filter. I use Amsoil Synunfortunately they have not released an oil filter for the 3.3 yet.
How much oil did you put in? requirements calls for 7.29 quarts for the GT engine. Did you do 7 or 7.5? Just wondering how folks are measuring 7.29 quarts.I just did first engine oil change at 2564mi.
Used Mobil 1 extended performance full synthetic + OEM filter.
Just start by putting in 6 quarts or so first. Then just use your oil dip stick to measure the oil level, that is what it’s for. Pour the remainder oil slowly after that and check your oil level via the dip stick to make sure is on the full marking.How much oil did you put in? requirements calls for 7.29 quarts for the GT engine. Did you do 7 or 7.5? Just wondering how folks are measuring 7.29 quarts.
.29 quarts is just over 9 ounces. I keep an empty qt jug with a mark at 9 ounces and use that as a measure.Just start by putting in 6 quarts or so first. Then just use your oil dip stick to measure the oil level, that is what it’s for. Pour the remainder oil slowly after that and check your oil level via the dip stick to make sure is on the full marking.
Remember it’s easier to pour oil than remove oil if you overfill.
Do more people not use Amsoil because it's expensive? I don't understand?
Whatever the manual says big homie! Us Aussies are pussies!
