ryan1stinger
Sustaining Member
- Sep 24, 2018
I’m going to answer the boost question,actually getting 21 lbs of boost from these turbos is BAD for longevity. ~19 should be the peak before the stock Turbo is just being pushed too hard.
Most of the 21psi guys are running upgraded FMIC, downpipes, intakes.... at the bare minimum you should be spaying some water/methanol injection if you don’t have any of the other mods if you are planning to run boost that high daily.
HUGE: Do not pay too much attention to brief boost spikes look at the boost is actually holding through the run. Most are going to HOLD the safer 19psi.
Sorry for the numerous posts here, but have you or anyone else found the boost limits for our stock turbos?
I reached out to Garrett by Honeywell regarding our stock turbos and here is the info they shared. Not willing to share the much needed data unfortunately. Too bad.
“I am with Full Race Motorsports, we are a Performance Distributor for Garrett.
Unfortunately the specs for the wheel sizing is proprietary information that can't be shared from Garrett. They are designed for the OEM application on the Stinger GT, so there isn't any data to share with you regarding supported boost, compressor maps, etc. “
Hope there’s progress soon on DWGC or whatever Terry said would completely resolve it.
