EBdiesel08
I have the 2018 GT1, do the Stingers have heated mirrors? I see some squiggly lines on the mirror, wondered if that’s what that meant or if was that the mirrors dim based off light hitting them. Thank you.
Now, where did you learn that?They will heat up with the rear window defroster.
Every car I've owned had the heated mirrors connected to the rear-defroster. Not sure why there isn't a separate button/switch?Now, where did you learn that?
Ok thank youThey are heated.
a. Try and error and b. there is the rear window heater Symbol on the glas in one of the CornersNow, where did you learn that?
The mirror has a little squiggly lines icon on the mirror.
Well, dang!a. Try and error and b. there is the rear window heater Symbol on the glas in one of the Corners![]()
