Mike_TX
The specs on my Premium call for cold tire pressures of 36psi front and 39psi rear. That's pretty high in my experience, especially on the rears. In the hot Southwest, those tires are going to go to 44-45psi at highway speeds in the heat of summer.
I'm more accustomed to fronts and rears both having the same pressures, and those cold pressures being more in the 33-34psi range. (Note that I do not have the staggered wheels/tires of the GT's.) I also figure the "hard" tires contribute to the thrumming sound over expansion joints on roads.
So, my question is, do you observe the recommended tire pressures?
