Mike_TX
The Kia 8spd trans seems like a good one so far, but:
1. It is obviously geared to get into as high a gear as possible as quickly as possible, at least in Comfort mode. I noticed today while driving on a divided city street that at 45mph the engine was turning only 1250rpm. That's not even high enough to get on boost, but fortunately the 4-cyl has enough native torque to allow for good response, and max torque is only 300rpm away at that point, so I can still squirt away if needed.
2. Because the gearing holds down the rpms, I find that the engine lugs a little between 1000 and 1500rpm, making a slight rumbling sound under light acceleration. Unfortunately, that's right in the meat of city driving speeds (30-45mph), so I get the rumble pretty often. It doesn't really bother me, and more throttle will elicit a downshift and more rpms, but lugging an engine isn't something I like to do. I'm sure Kia knows this, and it must not hurt anything, so I'll just ignore it.
I don't know if the 3.3 behaves any differently, but I'd imagine the gearing is pretty much the same for the two engines. But then, the V6 probably doesn't lug as easily as the I-4, anyway.
3. The extra 2 gears over my previous (6spd) Optima 2.0T do help with gas mileage, though ... I'm getting an indicated 23.0 or so with the Stinger, whereas my Optima generally showed about 22.0 for the same kind of driving (80% city/20% freeway, Regular gas). It will be interesting to see how it does on the interstate.
Just some observations.
