Nice job !This fix has worked for me.
I've incorporated the suggestions of other members here.
Thanks to you all.
Worked like a charm on the trunk thunk.Just did this (with rubber m8 washers).
I’ll try hitting some bumps/potholes to see if the clunk remains shortly.
I tested the threaded bump stops before doing the washer fix, by applying a thin film of grease to the rubber and shutting the hatch. The grease transferred to the "landing spots" on the body of the car, so I knew they were making firm contact. No need to screw them out if they're already doing their job.I'm not sure if my hatch had the "fix" preinstalled before delivery but mine does not rattle. It did make a metallic clack over hard bumps when the bump stops were threaded too far out. The one thing I noticed is that the lower side bumper is rubber or rubberized and I see indents in it from the upper hatch plastic bumper. Hopefully this is "normal wear" and wont result on a rattle later.
Wow, this problem still exists and we are in the fourth model year for this car. Maybe it’s time that KIA finally fixes this issue already; a problem that has plagued my 2020.My 2021, with less than 600 miles just developed the trunk thunk. How has the fix worked for everyone? Still good? Do I just use the washers in that parts pack posted above?
Same part number s posted above?I went to my dealer and got the kit. Cost was $1.50CDN. I'll fix mine myself
