Wilzer
Please, please could I have a setting to select the AWD for 0 to 100% front wheels.
Sport is 80 to the back 20 to the front. It's awesome to be able to do that (even more fun, turn off traction control and go play)and still be able to go back to 50/50 when you need it.That would be curiousI wanted to say would like to select front wheels from 0-50% of total so at 100% it would be 50/50% front & rear how would you say fully RWD and no front wheel drive? Thanks
BTW do you know what the ratio is when you select "Sport" mode? Just curious, have heard different things. By experimenting, know "Sport" decreases amount of effort at front wheels
You can select sport and it goes 80/20. For me, the best setting is put it in custom mode, put steering in comfort and everything else on Sport and enhanced sound.OK, thanks, just set my AWD in Customize to "Sport" so I will get 80/20 right?
Say whaaat?There are threads that describe yanking a fuse and the AWD stinger effectivley is RWD.
Thank you for the detailed information, it helps understand what is happening and for me, helps me know what is happening to car while I am driving-hopefully stay safer.Drive power % is limited to the front, because the mechanical bits that transfer power to the front wheels aren’t beefy enough to send the full 375lbft of torque up front. Like transmissions, center diffs/power take off units/transfer cases are rated to handle a certain amount of torque.
Accordingly, 100% torque to the front is not feasible.
