Our stock intake system is very restrictive for a few reasons.
It’s mainly due to the kinked intake tubing that routes under the bumper, over the radiator and connects with small 1”x2” air inlets into the stock air boxes. Then it has to make a 90 degree turn through a flat panel filter with much lower surface area, and another 90 turn into the actual intake tubing of the turbo.
That’s a whole bunch of narrow twists & turns the air has to fight through before even getting to the restrictive flat panel filters.
Eliminating both those huge restrictions will easily provide 20wtq+ at low RPM with quicker turbo spooling, and extra 20-30whp all the way to redline from much less air restrictions at higher boost.
Beside the 4 cats on the DPs, the stock intake box is the most restrictive part of our Stingers and easily one of the biggest gains you can get for the money($110 total for 30whp+ at redline). I also dropped almost 0.2secs off my 0-60 times with just DIY high flow CAIs & heat shielding!
Lastly, they do make significant turbo spooling and blowoff sounds, but only under high boost in sport mode and here’s a sample below.
In Comfort or Eco mode you’ll barely notice any difference in sound. So unless your wife loves to use Sport mode and accelerate aggressively she probably wouldn’t even know it was changed.
Since you run more boost with the JB4 and already eliminated a lot of restrictions on the exhaust side, a high flow intake would significantly increase your power and benefit you even more than otherwise stock Stingers like me.
Hope this helps and happy tuning!
