ZyroXZ2
- May 26, 2018
Anyone got any tips or tricks to do this? I have conflicting info: the dealership claims that the entire engine/transmission need to be dropped to do it. Others quietly claim it can be removed on-car.
From what I've surmised without actually attempting it yet are a few things:
- The top coolant hose being removed seems to be enough space to move the turbo forward and angle it up and out (obviously the intake and turbo outlet hose would be removed)
- The primary DP and cat look to be the hardest thing to remove: top bolts are accessible from the top, but the bottom ones looks like it would require a combination of extensions and u-joints on an impact wrench from underneath the vehicle as there isn't any real "wrenching" room even if you got a socket wrench down there
- The oil lines seem to wrap around to the side-back area of the engine, but I haven't been able to specifically see where or if I have to remove those lines entirely to create enough clearance to move the turbo around
- The turbo manifold bolts are completely hidden by the primary cat and DP, so I can't entirely tell if all four bolts are easily accessible from above
If anyone has done this and can provide directions, or is an actual Kia service technician that knows the job, any help would be appreciated.
Thanks!
Thanks!
