From what I understand you can't.defaults to comfort mode, how you do lock sport mode?
You're probably right. I plan on keeping mine stock though when I finally get one so I hope they fix this by then.Some of these things will surely be switchable with aftermarket tunes as well...
Interesting, that was something I was trying to figure out too. I want to lock mine on Custom, but it doesn't allow you to do that from the custom driver settings and I haven't seen it in the configuration. Kinda annoying for sure.
Does it at least remember your last custom settings? Or do you have to go through and reset all of your custom settings each time you switch to custom?
Considering this possibility - I wouldn't be all that surprised if we saw something pop up on eBay or Amazon that allowed you to lock sport mode (alone, with no tune attached)...You're probably right. I plan on keeping mine stock though when I finally get one so I hope they fix this by then.
I'm not sure you will see this, but the 2018 model's shifter, when in drive, can be pushed to the left locking the car in manual mode the entire drive.Ya I think it's annoying the car does not save driver settings. I'd like to keep it in Sport Mode, Start/Stop off and Autohold on. Also it drives me nuts that there isn't a dedicated manual mode, every time you come to a stop it goes back into "D" and I have to shift down to put it back into "1" so I can decide when to shift into "2". Great car nonetheless... just some small tweaks really.
They fixed this in the 2022 model. It now stays in manual mode until you manually switch it back to drive.Ya I think it's annoying the car does not save driver settings. I'd like to keep it in Sport Mode, Start/Stop off and Autohold on. Also it drives me nuts that there isn't a dedicated manual mode, every time you come to a stop it goes back into "D" and I have to shift down to put it back into "1" so I can decide when to shift into "2". Great car nonetheless... just some small tweaks really.
Cable shifter FTW....So just here to say the gt1 did the manual mode that doesn't let go at a stop in 2018 ^_&
