Tonkabob
2500 Posts Club!
Bob did you post your data log with TPS? And agreed. Full throttle on the hit would do all we need to pull a decent 60'. You can't launch a Torque converter car any haigher than its hydro-mechanical flash stall allows. IT's not wet clutch trans. We are not going to get Higher RPM launch than TC allows.
Here are my 2 fastest runs that i have logs for - both 12.03s. The tune is slightly different between the two. We have been testing different things to hit the sub 4 second 0-60 and the sub 12 second 1/4 mile. The second graph has a small throttle pull at the 4-5 shift that i think Tork has a fix for. This shift bobble happens half the time currently. Also look at my timing during shifts often at 4-5 degrees vs 0 or negative for piggy backs.
