2019 Easy exit issue
Menissalt
North Texas
Question for anyone that has a 2019 with easy exit: is there a difference between standard and extended for you?
I had a 2018 for 2 days and with extended selected the seat would go all the way back. This was too far so I was just using the normal one but my 2019 barely moves back for easy exit and there's no difference between standard and extended.
Just curious if this is an isolated issue or something plaguing other 2019s.
Same here. I don’t see any difference. I’ve only had mine (2019) for 2 days and was planning on spending sometime tomorrow wrapping my head around all the features I haven’t scratched the surface on. This being one of them.
Update coming soon
I've initiated the seat as stated in the manual but this didn't change anything
Mine when set to my presets doesn't move at all even on extended because I sit with my seat almost all the way back to begin with. When my wife is in it, it moves way back as she sits with the seat moved all the way forward. I'm guessing it depends on how far back the sat starts out at.
With extended it went all the way back on 2018s. On my 2019 extended only goes as far as standard and that's nowhere near all the way back. Neither setting, since they're the same on mine goes back as far as standard does on the 2018.
I also tested this with the seat as far forward as I can sit in it and there's no difference between the two settings.
Update:
Just ran another test, it seems standard now goes back a set amount from your position and perhaps 2018s go to a specific location regardless of your settings?
