forzanerazzurri
- Mar 19, 2018
Thats really bizarre.@forzanerazzurri If you are referring to my car, they stripped it and did the entire process.
Sorry if you already stated this but did they strip the paint entirely and reprep the surface? Most shops will just scuff the surface and blast a respray over top. This would result in the effects of poor adhesion continuing with the new paint. I mean there is no other rational explanation here.
My primer is white, it looks exactly the same as it did before it was painted.
My body shop got into it with Kia. Kia stipulated a yellow primer that my body shop determined was inferior quality. My shop used a better quality primer (not yellow). The paint job looks awesome... so far. Will wait a few weeks before signing the release but so far the paint looks much better than original ... kind of like Heinz yellow mustard drinking a tequila sunrise at sunset in St Pete Beach.They did strip the paint off of mine, along with the primer the first time they painted it. I know only because the car was rejected by Kia NA because the shop here used gray primer instead of yellow and the Kia rep lost his mind.
The question that I had was around whether or not anyone here could say if the primer used continues to have issues. if so, this whole exercise is rather like pissing up a rope.
I entertain the same idea. From the promo book: "55% of the body structure [uses] hot-stamped, ultra-high-strength steel." Is this surface different from what Kia has used on previous vehicles? Could already familiar primer coats react differently on this steel?This has to be something that was new to them, because people in this thread are correct, paint isn't something they should be screwing up on, but a new build process and a new type of car (for the company) could be.
buy now or wait the 2019 model?Has anyone seen any 19's yet? I'm not even sure if they're on the lots
But if this were the case, wouldn't virtually of the Stingers be plagued with paint issues? Instead, we have relatively few, according to evidence so far. So it could be a complex of factors. And let's hope that Kia has worked through this already!
I called KIA and they said the primer was white not yellow. I asked them without divulging my primer color. They spoke specifically about the grey primer issue.The new primer specified by Kia is yellow, which is why @jondyer had to have his redone. Mine is getting redone with the yellow primer as well. Something doesn't seem right that they would use a different primer and Kia approved it.
VOC; Volatile Organic Compound. Salt Lake City adheres to a higher restriction (lower VOC allowances) than the rest of Utah. Repainters had better know the VOC regulations or they will get dogpiled on by the "regulators". Heavy fines.Why different specifications depending on state?
You are talking to the "master of inspection". Back there on 30 July I did a thorough go-over of all (then 16) Jerry Seiner Stingers. You can find the post. And I did the same thing today. There is nothing to report except "All Stingers on the lot are A-OK." The very first thing I look for is chipping/flaking/peeling under the forward, lower corners of both headlight assemblies.Look under the headlights, all 5 Stingers at my dealership had chips on the bumper under one or both headlights, even the GT2 on the showroom floor.
