VELOSSATECH INTAKE RAM AIR DUCT- Instructions - KHARTUNERZ - Ready for Purchase
NICK_KHAR
Authorized Vendor
Southern California
INITIAL 10 orders are getting a promotional price of $219
Subsequent orders will be at $249
If you want to a true ram air system for your Kia Stinger GT 3.3T or 2.0T. This is the hot ticket. Not only will you pick up the top end you crave, from our expertly engineered, low pressure drop, hi-flow ram inlets, you’ll be able to customize these inlet to your hearts content! Choose from 28 different colors for both the body (duct piece) and flare (mouth piece).
Choose your engine type, 3.3T for dual ram inlets or 2.0T for a single ram inlet to feed your intake.
Whether you drag race, roll race or drive spiritedly, the BIG MOUTH will give your Stinger the edge it wants and the top end it needs.
Velossa Tech Design is a world leader in 3D-printed aftermarket automotive parts. With the ability to color customize all of our products, we are pioneering color-customizable parts made in the USA with over 28 colors to choose from (the combinations are endless). All of our products go through rigorous engineering design, 3D print optimization and post-processing for strength and longevity as well as aesthetics. All supplied hardware is stainless steel for corrosion resistance and longevity. Our expertise in 3D printed automotive components is second to none – we like to push the envelope as we develop our own in-house strategies for 3D print production.
PURCHASE LINK
BIG Mouth Intake Snorkel Ducts - Velossa Tech 2018+ Kia Stinger 2.0/3.3
PURCHASE LINK
stingerVelossaTech (1 of 1)-11.webp stingerVelossaTech (1 of 1)-12.webp stingerVelossaTech (1 of 1)-13.webp velossatechcolorswatch.gif
Very clear instructions, excellent work VelossaTech :thumbup:
What chances would there be of water going in and thru to the airbox and air filter? From the side pic, looks like the snorkel is the same height/level as the airbox inlet.
If you’re fording a river then it will get in to the air box at the same height as stock.
In a heavy rain I could see getting some water into the box but not enough to cause an issue.
Your only hydro locking an engine when significant amounts of water make it to the cylinders.
Very unlikely, unless you are driving WOT in dense rain for a long period etc. I would be more worried with water accumulating at the bottom of the intake box, I am thinking of drilling a whole at the lowest point of the air box so that all the water just drains out cause I take my car to the carwash a lot and they do spray high pressure water towards the grill etc.
Tropical rain is common here along the equator, doubt you even need to be a WOT for rain water to get pushed in with ram air. And if you do get water pooling at the bottom of the airbox, I reckon you would have issues with hydro lock already by then.
Was told by a friend that there is a small inlet with a magnetic valve at the bottom of the airbox, and thinks it’s to allow more air in from outside the airbox when the charge air pressure gets too low.
I take it that the shroud is not re-installed?
I'll be putting on my "mcdonalds" colored duct tomorrow, or at least thinking about it. With the new wiring harness recall on Stingers... should I hold off? I looks like the wiring harness is part of the shroud, or I am wrong? If it is, what do you do with it?
The part of the harness for the recall is near/under the fender not the shroud portion during the install
Right on. Zip ties for the harness?
@NICK_KHAR
I did install these a while back but now that snow is happening and I do take 5 hr trips in snowstorms to go ride, I want to buy a prefilter to put over the velossa tech opening. I would just zip tie it out of an abundance of caution to reduce snow from ducking into my engine bay.
Can you please lmk the size of opening of the velossa tech inlet? Not sure if it is square or rectangle .. but hoping to not pull my bumper in freezing weather if you know that info. Thank you
@NICK_KHAR
Two words... Panty hose
