Base stinger 2,0 t 1st Oil Change
rocket23
1000 Posts Club!
Ct.
We all seen the bottom of a car and the oil filter, So I won't bore you with that. Mileage is 5500, So out with the old and in with the new. with pix of course.
This is what I installed hp -1004, pretty common filter.
notice the difference in holes.
found this, never seize these quick!!
IMG_0090.webp IMG_0091.webp IMG_0088.webp IMG_0089.webp IMG_0087.webp IMG_0083.webp
it took just over 6 quarts, hasn't been touched since it left the factory, I'm sure of this. I'm happy to report that the 2.0 base is an easy oil change. I had both the under side plastics removed because of dirt. But you only need to take off the rear one ,under the motor.One bolt in the forward center position shares in fastening both plastics that one needs to come out. All the bolts holding the under side plastic were way over torqued imo, so was the stock oil filter , I reinstalled with 8 ft lbs for the bolts. The oil filter was installed by hand, as tight as I could, BY HAND ! Thats the important thing here, even the drain plug was snugged up. then a a quarter turn....thats all that is needed imo..
Thanks very much for posting and taking all these pictures. Very helpful.
The picture that shows what the bolt screws into is clean, telling me the rust from the bolts came from winter road treatment and not flood damage......thank you Jesus!
yes the v-6 uses a cartridge set up, the 2.0 uses a common closed filter with a overflow bypass built in.
I have plenty of the regular oil oil filter from my hyundai sonata I no longer own. I assume they are interchageable with the kia one if the part number cross referenced.
The filter I'm using was earmarked for a 2014 sorento or a 2017 forte.......off the top of my head, yeah.
