Winter Wheel options
KSCHULZ525
I would like to get a second set of wheels with snow tires mounted. Can I get something in an 18" wheel that will fit over my Brembos and what is the size I need to look for?
If you find OEM 18s they are ideal winter wheels. Put 225s on them. A narrower snow tire has better grip than something wider.
Even 18"s from older Genesis cars would work well. I've got a set of 18x7.5 ET39 from my old '09 Genesis Sedan and they run just fine on my Stingers.
Just make sure the wheel hub bore is 67.1mm. Some of the earlier OEM wheels are 66.7mm. Hyundai/Kia/Genesis standardized on 67.1mm around the earlier 2010's.
Also, some OEM wheels use mag-style lug nuts with flat base, while others use conical lug nuts. No big deals either way, as lug nuts are cheap.
