start at the B pillar and just pull it off. The metal trim kind of wraps around the end of the rubber piece, but the rubber is so flexible you can just kind of peel it back. once the end is off it just peels out/off easily. the stuff on the doors is just pushed in between the rubber on the top and bottom edges. it comes right off. no snaps or clips or anything. wrap it and put it back in. you'll see how to get it off when you take a close look at it. the trim around the rear hatch has several clips holding it in. start at the low point and work up towards the roof, slow and easy. it helps if the ambient temps are not too cold so the clips are more flexible. I've had mine off a few times and even broke a couple clips. the rest of the clips hold it in just fine. one note, when you get to the top of the hatch, by the roof, the last clip is actually designed to slide off a little metal post instead of just popping straight off like the other clips. I can't remember if it slides towards the rear of the car or towards the roof, but it only slides one direction and it only has to move a few millimeters to come off. I also broke one of those, but again, the rest of the clips still hold it on just fine. Hope that all makes sense.
