Windbooster vs Dealership
RaiderMike760
Should I take off my WindBooster for a simple oil change at the dealer? Please share advice and experience. Thank you
Nah, the probably don't even know what it is.
Naw no need.
No I left mine on with no problem
As long as you got it tucked behind the pedal in that carpet cavity you should be fine.
Gotten 3 oil changes, and body work done on all panels, etc. Never did they locate the bms pedal in my case. Even if they did I would just simply state idk what that is I bought the car used it may be the previous owner. I will research it in my free time and see how to remove it :). Until then it stays on and gets forgotten. I set mine up to the max setting. Allows for less leg movement and easy full throttle for defensive driving n such.
Dang max is too sensitive for me.
Me too. I have mine on min, but I always drive in sport mode too. If I’m being lazy I can’t pull away with smooth throttle it’s so sensitive.
Oh, the only difference in my case is I have to let off and let it go down another gear. So my coasting rpm in city is around 1-2k in Sport mode. 2.5-3k on highway.
I just enjoy max sensitivity bc it's less straining on my legs, after working 12 hour shifts coupled with college in the morning haha.
