Will these work
Fastfreddy711
I have these plugs. will they be ok in the stinger 2.0 version??
HKS 50003-M45XL M-Series Super Fire Racing Spark Plug If so what should i gap them to? if they wont work what maps should I limit myself on with the JB4 and my stock plugs gaped at .22? Map 2 Map3??​
yes those are 2.0 plugs. leave the gap as is. it could be adjusted but usually not needed in hks. you need to press the strap closed if you did adjust gap, not a feeler/spreader style. so leave as is otherwise
and do not use stock plugs for anything but stock. they suck. $20 plug can ruin the engine fast
Thanks for your reply, Why would the guy from Burger tell me I should be fine with stock plugs gaped at .22 on map 1? retorque question. Anyways I didnt gap them, so just install and what would be the highest map I can use ..with proper gas octane and be safe with these plugs?
terry says you can use them on map one as thats the only map remotely possible to do so. could it work out, sure. but its not wroth the risk as stock plugs in these cars are junk in normal conditions as is
you can use any map you want with those plugs IF you meet to requirements listed on the jb4 page stating what octane fuel is minimum. the safe "good daily" level IMO is map2 and 93 octane fuel.
