Will an 8.5 and 9.5 inch width setup work on stock tires?
GhostGrey
Found a nice set of wheels
5x114.3
19x8.5/9.5
+35
Will the stock michelin sport 4s fit on this setup? And will this fit without an issue on the car.
Should fit. I have 5mm closer clearance with the suspension in front than that, with the same width front and rear; I'm 4mm further in, in the rear; I use Michelin PS4S, and PS4 OE before that.
I have just added some aftermarket wheels in 8.5 and 9.5 on oem size tyres. Mine are 40 offset on both.
The tyres are a little stretched, but I'll wear them out and go wider!
I'm using my OEM PS4's on 19x8.5 front (+35) and 19x9.5 rear (+40) ... as Hilleagle says, a wee bit stretched but within specs.
