Offset is where the wheel mounts relative to its centerline, with a positive offset putting the wheel hub closer to the outside of the wheel, ie tucking the wheel further inside. An inch is 25.4mm (and a cm is ~0.4 inches).
So, if the fronts are 19x8" with a +34mm offset, it means that the wheel mounts ~1.33" outside the wheel centerline. Instead of 4" of wheel inside and outside the hub surface, it's more like 5.33" inside and 2.67" outside.
The rears are 19x8.5 with a +46.5 offset, or the wheel tucked in ~1.83". Instead of 4.25" of wheel inside and outside the hub surface, it should be 6.08" inside and 2.42" outside.
In other words, going from front to rear you add a half inch of wheel width, which at the same +34 offset would mean a quarter inch inside and out, but your offset is 12.5mm higher, shifting the wheel inward 1/2". So the inside edge of your front wheel is about 3/4" further inward, and the outside edge is about 1/4" further inward.
(This is relative to each wheel hub, so if the fronts and rears were in the same plane you'd have the rear wheels 1/4" inboard of the fronts, but the rear hubs are almost certainly set wider than the fronts.)
