Wheel spacers
SneakerB
Bought the wheel spacers that ive seen recommended on here multiple times put them on about 2 months ago and today while driving to work i heard some grinding and the car felt a little shaky and i pulled over to see two broken lugs and 3 loose lug nuts on my back right tire. Good thing i pulled over to check before hitting the highway or it would of been catastrophic!
scary. do the spacers leave you with very little lug length to secure to?
Theres plunty of lug as there the ones with seperate lugs attached to the spacers
Glad nothing serious occurred like you said.
Can you tell exactly which ones or a link to the ones you have?
the utterly creepy thing is that you don't always get a warning from vibration. do you recall seeing a dash cam view, shared on here a few weeks back, of a freeway wreck involving a pickup truck that shed its lf wheel right in front of a passing suv, which ran over it and got flipped probably ten feet into the air and came down upside down. the wheel just 'waited' until it was too late to avoid and then popped off like it had an explosive charge behind it, it was that abrupt and violent.
