What the best tuner for the gt2
IMHO, JB4 tune with bluetooth connectivity.
JB4! :)
Is it possible that some one can post a site of the JB4 so I get the correct item please
thanks . i hope its worth it. i bought it, what else goes along with it that i should get
It comes with no instructions so use their online instructions located here:
And here:
Also for the fuel wires you can tap into the factory harness with the provided posi taps or many people get a jumper harness that they tap into and can easily remove when taking the car in for warranty work. Ecko makes/sells them here on the forum, BMS sells them, or they are on ebay (this is where I got mine just search ebay for “stinger fuel wires”).
If you want a clean looking install you also might want to look at getting a cover that goes over the top of the tuning box. Burger has them on their site but they are listed as backorder. Do a search for TonyG on here and get in contact with him and he should be able to get one out for you. You can order one for both sides or just the passenger side it’s up to you.
Lastly you’ll need some 3M automotive double-sided tape and a couple zip ties. You can pick this up at walmart or any local auto part store.
I order it and plugs and air intake
Will I get more hp. I just got the car so I don’t even know how much hp is on stock car
You will get more HP, but how much depends on your supporting mods, if you did fuel wires or not, and what map you are using, along with other items such as fuel, etc... I want to say I've seen some generalized expected results posted around here somewhere. I'm sure someone may have those numbers before I could find them again.
I'd recommend getting the spark plugs gapped and replaced at a shop
Real pain in the ass to replace (one of) them yourself.
