2.0T What Map do I run?
Map2
Double post, oopsie.
If you want to go higher than map 2, you need more octane. There is the method of adding octane booster, adding a mixture of E85 in a tank or going WMI(Water Methanol Injection) or CPI(Charge Pipe Injection) . But before you go higher than map 2 you should probably upload some logs for them to be checked out. This will give all the information needed to see if you should move forward or not.
