What boost level you running on map 6 running 93 octane ?
mikegt2
Looking to trying map 6 running 93 octane, what boost levels through rpm range are you running ? like to data log some runs starting boost levels around map 3 and send to someone that knows how to read the data logs.
If not looking safe will get the back end flash to possible add more boost safely.
What's the point of running map 6 with only 93?
You're most likely at your fuel limit with map 3 already...
Ok so your saying 4.5 -5 lbs of boost over stock is most you can run using 93 0ctane ?
Map 3 is 6psi over stock and tapers to 5psi on the top on and ya map 3 is about the most you should run with 93.
Look on Fbook for Will Hatzer and map6bot@gmail.com (IIRC). It's an automated tool to read your logs and tell you if you have issues.. I'm looking to try it myself soon.
