What are the different mappings?
This is my final findings with RC chip with here in BC Canada once I changed brands of gas , which was recommended by the a local tuner here at Classified Motorsports, told to try 91 Shell V Power ,
and use the Boostane brand of boost for an increased octane values for RaceChip 93-98 which ,
I now have finally done ✅ limp mode problems where challenging both on or off the track under heavy throttle using the strongest RC mapping! The Gas here In Kelowna BC is of poor quality but since I changed to the Shell Vpower 91 and used octane boosters to bring the octane level up to 98 when,
I was using their strongest Race Map :) THe results we’re better than expected! I am not reporting to promote either the PT tune I have , RaceChip or the Gas stations , but my finding s are based on facts with numbers !
March of 2019 DynoCom Dyno run 356.5 Awd whp :) 502 lb ft torque using strongest RC map stock tune with all my Mods :) using Chevron 94 plus boost!
May 13 2020 DynoCom Dyno run Mild tune + RC chip on DynoCom Dyno runs
, came is at Awd whp 409 lb ft torque 508 , running of Shell Vpower 91 plus octane boosters to 98 :) no timing being pulled :)!! All testing done at approximately 1000 ft above / 350 meter Above sea level ,, View attachment 42379
The JB4 is the most popular tuner for the Kia Stinger for a reason. Follow the link to learn more!
05DCAE14-F822-4E15-A03E-5B6DE054F4AB.webp This first Dyno was March of 2019 ! And second May 13 2020
This was my fastest 0-60 Dragy check to date at 4.38 sec weight 4312 lbs or 1960 kgs ! D501CCA0-EBB7-4639-9A0D-CB7AF913BB04.webp
You hauling gravel or something? Why is your car so fat?
It has the spare tire and fully fueled up lol But every test I ran was pretty much fully fueled as if you were heading out for a long ride lol this was done on the DOT / CVSE scales and those we’re the numbers and weight twice , Yupper my AWD Stinger GT is heavy :) and my only Car lol
It has the spare tire and fully fueled up lol But every test I ran was pretty much fully fueled as if you were heading out for a long ride lol this was done on the DOT / CVSE scales and those we’re the numbers and weight twice , Yupper my Stinger GT is heavy :) and my only Car lol
Were there people in the car when it was weighed? I don't understand why your car would weigh 300lbs more than Kia's advertised curb weight for identically spec'd Stingers.
