robz32
Texas Stinger Swarm
Mine does that too, thought the bottom piece was coming off or something. I don't really look at it from that angle much though, Lol.
@MerlintheMad , he's talking about the black plastic piece under the car, not the painted panels.
The only solution is one I posted a few months back. An aluminum splash shield.
Agree, it seems like a bad design or a flaw, because it isn't like that new it gets like that overtime. I have the same issue and it will be a problem when reversing, there is a good chance it will hook into something. Problem is worse obviously for lowered cars like myself, I was trying to think of a solution when I was under the car the last time but couldn't.
Solution to what? What "issue"? Unless you reverse over something you have no business driving over to begin with, nothing is going to happen. I don't see the oil splash shield turning into a sagging mess even with oil getting on it. The plastic will handle surface oil. (Besides, it would take a real hack of a mechanic to leave oil all over the shield.) It's not as if the material is going to absorb oil. Those hex nuts look hefty and the plastic looks stiff. Why do you think it will get worse as time goes on? This is another reason to look under a bunch of brand new cars on a dealer's lot and see what they look like. I am betting that every one of them will have a low trailing edge on the oil splash shield. (Unless MY19s don't have the same splash shield arrangement.)
LOL! "Under"!If you get a chance try getting under the car and you will see for yourself.
