Wash/detailing suggestions
DGambit
I’m curious as to what people recommend on with washing and detailing products/methods on their Stinger? I’ve been looking at foam cannons but there’s a ton out there ranging from $15 to $80 but I don’t know enough about them to know if there’s a major difference.
There is a million very good car detailing videos on YouTube, knock yourself out.
One of these "what do you use to clean your car" threads gets started every couple of weeks or so. I always say the same thing: Optimum No Rinse (ONR), a gallon of distilled water, six white hand towels; turn the towel surface over the instant you see it coming back not clean. I use distilled water with ONR as my main spot cleaner too. If something doesn't come up, I resort to isopropyl alcohol, very sparingly. So far, I haven't had to go for anything stronger. (Oh, and I wash my car weekly, sometimes more often than that; not letting grime accumulate/sit is the first rule of easily maintaining a clean car.)
No offense, but ONR Washing is a last resort. The first priority in car detailing is paint preservation, ONR is far from ideal.
No offense, but ONR Washing is a last resort. The first priority in car detailing is paint preservation, ONR is far for ideal.
ONR is made to shield clearcoat/paint from direct contact. A protective coating is left behind, which is maintained over time with repeated use. It is far from the last resort. It helps prevent swirling/spiderwebbing of the clearcoat. You can't hurt the clearcoat if it doesn't get filthy and sit in the first place.
I understand perfectly what ONR is capable of, and it should only be used by people without access to plenty of water or a space to properly wash your car.
It should not be recommended out of the gate. Your car, do what you like to your car, but don’t push least preferable methods up front.
How is fast and easy less preferable? Of course you can add on details and really get into it. But realistically, most people most of the time do not have several hours to spare each time they wash their car. So, they wait until they do, and their filth accumulates and the clearcoat gets scratched. Much, much better to clean often. And if a c. half hour wash works to get you to do it often enough, that is a preferable method, in my humble opinion.:)
Foam cannons are a WANK , I have one from my BMW days , come and get it for Free !!
As @westcoastGT say’s, foam cannons are a wank, they are marketed as a pre soak, WTF.
Just give your car a good soak before with water & use a high quality Ph neutral carwash + microfibre sponge, wash the car in stages & rinse as you go.
To the OP, your best best is to research away from here, this thread is already full of bad information.
Foam cannons are just a delivery method, and use quite a lot more soap than is strictly necessary. But I still use one :)
For general cleaning, here's what I do, there are lots of other specific things you can do to your car that aren't required on a regular basis.
Put your wipers in service position.
Grab your pressure washer and blast the entire car to remove any road grit, pay close attention to those brake vents because they'll transfer grit to your mitts/cloths later.
Once all loose debris has been removed, grab your foam cannon (my pressure washer came with one, works fine), load the whole car, I use a cheaper Meguires soap for the presoak. Wank or not, I like this step. You can just spray water on the car, but then it evaporates, leaving the dirt where it was. The bubbles prevent evaporation allowing the water more time to loosen that surface dirt while you're doing other things.
Fill 2 buckets with warm water, add soap (follow instructions, I like CarPro Reset ) to one, other will be for rinsing. Do this while the car is soaking.
Use a wheel brush (totally depends on your wheels, one that can get between your spokes and into the barrel, I use something like this ) to clean the barrel of your wheels, between all spokes and the face of the wheel).
When the wheels are done, pressure wash or hose the whole car again.
Practice safe washing, mitt goes in the soapy bucket, onto the car, into the rinse bucket and scrub the mitt with your fingers, mitt goes in the soapy bucket, back onto the car.
Wash the car from top to bottom. I start with the roof and and windows, rinse, soap, doors above the shadow line, hood, trunk, rinse, soap, front bumper, rinse, soap, doors from the shadow line down, rinse, soap, back of the car, rinse.
Pressure wash or hose, paying particular attention to all seams.
Microfiber drying towel.
Detailing spray like Renny Doyle Bead Maker (or whatever you want), wipe on, wipe off, get those last drips. I do my windows with this too.
Do what you want, there are a lot of opinions here, there are many like it, but this one is mine. I must master it as I must master my life.
thanks for the tip on the vents, I didn’t really think about that but it makes a lot of sense.
I know this is off topic from what OP is asking, but I wanted to mention this.
If you ask 100 detail guys about detail products/methods, you will get 100 different answers. But most will agree that putting down the first layer of protection such as ppf/ceramic coating or even wax/sealant is foremost step in preserving your clear coat and paint. If there are swirls in the clear already, as even new cars do, it would be recommended to do a paint correction before the protection layer. Don't forget that even the best protection products needs routine maintenance. With your protection, you can do almost whatever you want as cleaning process. Washing will clean the dirt off, maintaining protection layer will keep your car shining.
I agree with you 100% I was just curious as to what stuff some people here may have had the best success with, but then again I also realize that could be a different answer for each person to. I see what you’re saying with the protective coat/sealant and then do what ever within reason.
I just see dozens of product out there from stuff like F11 to Nexgen and some other fancy named things and they range tremendously in price. I guess I’ll just try one that’s rated overall good and go from there
This has been really helpful though so thank you all for the help and the input!
Because the beauty is in the eye of the beholder, every product will look different from people to people. Some like the traditional warmer gloss wax look, while some prefer the synthetic gloss. X branded product that someone swears by may not be something you'd like.
My best advice would be to try some of the popular products out there starting from low to mid price range. If you find the look you are happy with, stick with it, otherwise try something else. Most of us Joe's of the world will be happy with outcome of off the shelf product. Difference between uber-expensive versus lower cost product has almost negligible outcome. If you don't know what low cost product looks like to begin with, how would you tell if $100 product made a difference or not? Idea here is to get a baseline and get your eye trained, then you can move on to something better.
Don't get caught up in marketing hype either. I know there are millions of types of products out there. I stick to simple formula.
PPF > Ceramic coating(actual coating. pro or diy, not the spray stuff) >>>>>> Sealant > Wax. Just remember lower tier products like wax will require more frequent maintenance. Don't skim on your first layer of protection, do the best your budget allows.
If you just want a nice shiny car without spending hours of your free time, I would spend the money and pay a professional for paint correction and ceramic coating(ppf if money is no object). Wash your car with two bucket method every two weeks or so and be done with it. Trust me, you don't want to jump into detailing rabbit hole. Once you start seeing the defects, you will never un-see it and this will become your weekend obsession. :)
That’s some real solid advise, starting with a good midrange priced sealant and avoid the ceramic sprays sounds like a good place to begin. I might check a local guy who did an amazing job on a friend of mines car for some professional stuff.
look up chemical guys, i use there products and some Adams products.
Youtube is full of detailing videos and chem guys have videos to show how to use there products.
Its actually a very addictive, nearly a hobbie lol
My routine wash: Snowfoam>high pressure rinse>bucket wash>rinse>dry
For coating Soft 99 Fusso Coat 12 months is probably by far the toughest sealent there is. However when applying ensure surface is well prepared and I cannot stress this enough, use as little of it as possible on the applicator, otherwise you will end up with streaking/smudges & then you'll have to restart all over again. Especially with darker colours.
No need for ceramic coating, and I'm not a big fan of polishing with machine because your always cutting a layer of the precious clear coat.
