Warpped rotors issue
Howdy and welcome. Tell us your story of your brakes adventures, since that's how you chose to introduce yourself. :D
Like alot of other owners the first set warped. Kia installed another different looking set. They lasted half as long. So I was fed up with what they offered and bought the slotted ones from Khar Tunerz.
So, this topic is a deadhorse and at this point, it's probably horse soup as it has been beaten so much. The issue is the pad residue that gets left on the rotor surface which makes it feel like warped rotors when it is in fact pad residue. Many on here have swapped out pads with success. Hopefully you also swapped out your pads with either aftermarket ones or there is a OEM Eurospec pad that Kia has been somewhat replacing pads with. I don't ever seeing someone just swap out the rotors themselves and leave stock pads so it might be interesting to see if it comes back for you.
Damn. I was kind of thinking that after the shop said the rotors had almost no runout. I'll try the pads , thx.
