Tyre Pressure
Cashie
NW Western Australia
What tyre pressures is everyone running?
I've found at 36/37psi my Continentals ride pretty firm, I'm about to replace them with the Michelin PS4 tyres and interested in what pressures everyone is running.
38 all round cold.
38 all round cold.
I was running that and in the hot weather I was seeing temps around 41 psi and experienced a very firm ride.
You on the Continentals or Michelins?
On Michelins, correct 41-42 when hot. 4psi rule in effect. Yeah can feel firm, but not uncomfortably so but I do drive on comfort susp setting mostly. My wear is very even.
Maybe try drop the front to 37 cold. But I found tyre placid @ 36 front was far too soft for me.
Cool, I'll have a bit of a play around I think.
I ran at 38psi cold until I saw how my rear tires were worn. Just slightly more in the center. I’ve brought it down to 36 just like the tire placard says
Conties 38/40 cold with even wear.
As per the manual. 36 front 38 back cold. Michelins.
DITTO. Filled mine tonight. Cold tires, after the cold front passed. Lost 4 to 6 PSI on all four tires after the temp dropped from 90 to 70.
