Hello, has anyone had a problem with the turbocharger?
I get an error: (errors detected in ASO)
1. Turbocharger boost control position
"B" on high limit
2. Steering position sensor circuit
turbocharger "B"
After the light comes on, the car noticeably slows down. switching between sport and comfort makes no difference.
I bought obd from Allegro for PLN 40, it detects 2 errors:
P2586
Turbocharger (TC) boost control position sensor B - circuit malfunction
P25A1
Turbocharger (TC) B, boost pressure control - higher limit reached
If I manage to delete it, the car runs normally and has the power as before, but after the third start of the car the error appears again
did anyone have such symptoms, the dealership said it was a lot of work, the engine had to be removed and it cost a lot.
"B" on high limit
turbocharger "B"
P2586
P25A1
