Turbo oil drain tube bolts
snowwhite3.3
Any suggestions for re installing the bolts into the oil drain flange in the bottom side of the turbo?
Loosen the other side of the drain hose and you'll get more play
I have both bolts out of the drain flange now, as I have just had the head off. Do you mean the end going into the block?
Have you accessed that while it was on the car? Seems impossible to get to from where I am looking at.
Swivel 1/4 " 10mm and extensions are your best friend
Thanks, I'll take a look tmrw.
I know you need to remove ac comp. On the drivers side. Pass may be behind the motor mount. I've done it only with cradle out of car. But it definitely looks doable inside the car
