TSW Wheels Nürburgring Brembo Clearance
klikaiwen
I like in 18inch wheels and due to unsprung weight and tires availability
I decided to go with this wheel!
I have a g70 and planning on running 245/40R18 and 285/35R18
However I am getting the 18x8.5 +32 version, but wondered if I could clear the Brembos without spacers
I really do not wish to install any spacers.
How much clearance do you have on the 18x8 +35 version?
If anyone can let me know that would be great
I know
oddball​
has 18x8 +35 but I was not able to found a way to do private messages to ask him
Hi. You're talking mere millimeters difference between your choice and what oddball is running. If that clears, yours should too. Welcome. Hopefully someone will give you a definite empirically accurate reply. :P
Hi. You're talking mere millimeters difference between your choice and what oddball is running. If that clears, yours should too. Welcome. Hopefully someone will give you a definite empirically accurate reply. :p
Thank you
oh lol coming from a Miata ND a few milliliters means learning the Brembo or not XD
Why in the world would you want to push clearance that close?
because sadly that's how they come stock lol, It barely clears stock brembos
Aftermarket wheels gives more clearance with same offset
However if you go with a different design wheel with a lower offset then it won't clear since Brembos are big and these are 17 inches.
17"? Your OP said 18".
BTW, the private message function on this board is a bit unusual. Click on a user's name, then click "Start conversation". You get to your messages by clicking the envelope icon next to your name on the top bar.
