Trunk Rattle?
Yojimbo
Hello everyone! I will keep this quick as there have been many forums about the trunk rattle in the Stinger platform.
I think my issue is not a trunk rattle, but when driving at normal speeds and faster with the windows closed, the car makes a weird noise inside. Almost like when you have one window open and you get that annoying wind noise in the cabin.
The other day when it happened, I looked in my rear view mirror and either the mirror itself was shaking or the trunk was. It almost feels like there is air building up in the car and has no way to escape, not sure if that makes sense.
Either way, I just wanted to know if this has happened to anyone else before? I will say I currently have an aftermarket exhaust but this used to happen with the stock one as well, but not as often. It used to actually be much worse with the stock one, but rarely ever happened.
My warranty runs out this month, so I think I will book an appointment and have them check it out anyways.
Thanks in advance!
check your hatch lid mounting bolts for looseness. check your hatch and doors weather seals. make sure none of your undercarriage panels are coming loose / fluttering. the noise as you describe it could be so many things.
