Lampaaaa
- Jul 17, 2024
That's just about the only logical path forward.That's new. Clean everything real good, and recheck after a day or two to see where exactly it's coming from.
That is an extremely difficult to believe root cause.I had a big leak on mine which was caused by running to big of a tire diameter difference between front and rear tires. Dealer did replace it but my leak was substantial. They said the transfer case cracked and leaked out almost all the oil.
I ran 255/35/19 and 285/30/19 with JB4 (map2). It happened after aggressive driving mid August. I don't know what could've caused such a pressure buildup to crack the case but the combo of more power, too big of a difference in tires and the extra grip is no good. Surprisingly that combo took 40k kms for the transfer case to fail.That is an extremely difficult to believe root cause.
Running too large of a difference in diameter should only prematurely wear out the clutch pack in the transfer case!
Awesome that they sent you a video, but they really didn't show the crack at all. Just shows that oil has been leaking.Here is the video from the dealer mechanic showing the leak:
Just curious what shop did you take your car to? I’m around Toronto area aswell.I usually drive it in custom mode with sport diff (80:20 split) but not in sport engine/transmission mode.
I am not sure where the exact point of leak was. I wanted to speak with the mechanic that worked on the car but they were off that day and forgot to follow up with them, so I can't confirm the actual failure point.
