Hi guys,
Strange things started to appear with Stinger
3.3T.
Enormous amount of vibration/shudder appeared twice. Was driving very easily between 40-60 mph. Experience like driving on very rough road or like having a blown tire. Both times I gently stopped, put in parking, went around the car checking wheels and started driving again. Vibration was gone.
Scanner shows no codes, neither misfires, nor powertrain.
Did anyone experience similar symptoms? Possible that torque converter is about to fail? If so why there are no codes?
Hey man, sorry you're dealing with that, sounds super unsettling. I’ve been around a few cars that showed similar symptoms and here’s a list of most likely possibilities based on what you described
Driveshaft or CV axle issue – A bad u-joint or CV joint can cause serious shuddering and banging, especially if it’s starting to bind or about to fail. The fact that it comes and goes could point to something in the drivetrain binding under load and then resetting when you stop.
Center support bearing or carrier bearing (especially with AWD models) – These can make it feel like you're driving over rumble strips when they go bad. Vibes can echo through the whole car.
your Torque converter– Yeah it
could be failing, especially if it's locking up weird or slipping under light load. But usually when a converter starts dying, you'll get codes eventually—P0741, P0744, or even transmission temp warnings. The fact that you’ve got no codes or slipping at gear changes might point away from this unless it's early stages.
Trans mount or engine mount failure – If one’s completely toast, it can make the drivetrain shift and thud, causing momentary banging and vibration that disappears after things resettle.
Diff or rear subframe bushing issue – If that banging really is coming from the rear first, maybe a rear diff mount or bushing gave out or is about to. Especially on hard decel or load change.
If it’s not speed dependent and feels like it just hits out of nowhere, I’d lean toward something
mount or driveshaft-related over the converter for now. Might be worth jacking it up safely and checking for play in the driveshaft, axles, and rear diff area.
Let us know if it happens again or if you can feel it building up to the event. Hope it’s something simple
