AF_kiastinger
- Sep 29, 2020
I have 8.5 wide wheels in the front and 9.5 in the back. Whats an ideal number to keep my tire pressure at?
That PSI is usually your "cold" PSI and tires will increase several PSI just from driving and the heat in the day. When we autocross we end up letting a few PSI out after every run, since they will heat up that much just after one. While our targets might be different in that application, I would recommend setting to the cold number on the door IF your tires are cold, say 70 degrees, shade, no driving for a few hours. When it gets real cold, like sub freezing, you should add a few to get you back into the normal range.Best bet is to check the label on the driver door jamb. I usually add ~2 pounds to that to account for temp fluctuations and slight leakage over time, but for all I know the manufacturer already accounted for that.
I ran recommended psi on my first set, and the outer (especially left) tire edge wore down much faster than the center: the tread was gone on the outer edge while I still had some millimeters to the wear bars in the center. When my wheel/tire guys swap wheels and raise the psi their standard is 40 psi. I've been running 40 psi all around. The rears were recently replaced and the wear was pretty even (the first wear bars to touch were the outer edge of the RR). So far (with c. 4K miles to go) the second set of fronts, run continuously at 40 psi cold, look to be wearing evenly. So, at this point, I think that if you corner aggressively, a higher psi than factory recommended is necessary to prevent premature outer edge wear.There isn't a lot of space between tire and wheel for give. I run 40 lbs.
39-40 cold works for me. I read a rule of thumb somewhere that a 10 deg F drop will lower psi by 1. My observations seem to support this. Even when I fill to 39-40 on cold tires, I still occasionally get a first reading of 38 on the display (and yes, I have checked for agreement between the car's reading and my gauge). And this happens in sunny, temperate South Florida.I've been running 40 psi all around. The rears were recently replaced and the wear was pretty even (the first wear bars to touch were the outer edge of the RR). So far (with c. 4K miles to go) the second set of fronts, run continuously at 40 psi cold, look to be wearing evenly. So, at this point, I think that if you corner aggressively, a higher psi than factory recommended is necessary to prevent premature outer edge wear.
I try to not get OC(D) about this: my handheld tire gauge reads c. 3 psi above the 40 psi that my tire and wheel place inflates to: while the TPMS indicates between one and two psi over the shop 40 psi. Then, when I drive around for a while, I'll check the TMPS and inevitably all four tires will vary from all showing exactly the same psi, to the highest being three or four above the lowest. Strict accuracy is not possible, and neither is consistency.39-40 cold works for me. I read a rule of thumb somewhere that a 10 deg F drop will lower psi by 1. My observations seem to support this. Even when I fill to 39-40 on cold tires, I still occasionally get a first reading of 38 on the display (and yes, I have checked for agreement between the car's reading and my gauge). And this happens in sunny, temperate South Florida.
