Tire experts
Schroedes
So many options and i searched through a bunch of threads.. just looking for some verification from some of you with aftermarket rims. I have Vertini 19x8.5 with +32 offset and 19x9.5 with +38 offset for rear. Im wanting some nice performance all seasons, im thinking continental extreme contact plus. I wanna upsize some to fill the wheel well a little, without messing with performance, speedometer etc. Whats the max i can go or of any of you have experience.. i have 235/40/19 for front and 265/35/19 for rear in one of my carts. Thank you
Rims are on order btw, lining up tires ahead of time
These combos should work as well
245/40/19 275/35/19
Or
245/35/19 285/30/19
You can go to getyourwheels, select your wheel, and specs. They give you the option to add tire sizes with staggered combos to give you an idea.
I'm running an overall diameter of 26.7" without any clearance issues and the speedometer is only off by a negligible amount.
245/40r19 front and 275/35r19 rear are roughly this diameter and have been used by others without issues.
Any impacts on handling characteristics? Negative or positive, running those sizes?
Nothing really negative, unless you're planning on driving in snow with them. The extra width could be an issue with that. I run dedicated snow tires in winter and summers for the other 3 seasons. You'll get a bit better ride comfort with the extra sidewall.
I have your same fitment but Stance wheels [same company pretty much]. I have 245/35, 275/30. The best option would be 245/35, 285/30
You have no clearance issues with the 245s in front?
Got any pics ?
245/40/19 275/35/19
Or
245/35/19 285/30/19
Getyourwheels - thanks for that :cool:
245/35/20 & 285/30/20 - anyone cruising with those dimensions?
I’d really like to fill those wells properly esthetically and still keep most of my Stingers driving comfort.
0-60mph is all I need - Norwegian traffic laws… :rolleyes:
Will 285s fit on a 9.5 inch rim??
I can't decide.. trying to keep diameters close in front and back. I'm thinking either 245/35 with 285/30, or 245/40 with 275/35..
Well I just ordered Continental #xtreme Contacts, 245/40s with 275/35s. 32 offset in front with 38 in back, should do the job.. didn't think it would take so much research to size up tires and it's hard finding em in stock. Thanks for the help gentleman
