Sunroof Question
Johnman
DFW, TX
I hope this is not a dumb question, but-how do you open the sunshade without opening the glass?
Lightly tap the button backwards.
By the way, that’s not a dumb question either:)
Just another question about the sunroof. Can you tilt it or is it just open or closed?
You can tilt it, just lightly tap the button up.
Yes, tilt and open depending on which way you press button.
You know I read that in the manual but can't seem to work it out on the button. At least now I know you can do it. Thanks guys.
If I remember correctly, you push in the button. The button works like the volume control on the steering wheel. It toggles forward and back. You also can push the button in like you are using the mute feature on the steering wheel
That's probably why I couldn't get it to work. I was only pushing it forwards or back, never in so will try that next time.
Once you get the “feel” of the switch it will be easy to select what option you want eg: either just screen open, tilt or full open or close which leaves the blind open that’s the challenging one...lol.
Yes its one multi-functional switch that needs a little practice.
