Stock front rims all the way around
Fast86gn
Can you run four fronts all the way around with same size tire and rotate?
Yes. The 225 tire squared is a good size for winter driving too, being a bit narrower, thus having better grip in the snow (if that is a factor for you).
I would think it would screw up the speed sensor and the ABS.
I'm in TX say no winter tires. On the Speedo difference I would think the changes could be made with HP tuners? I'll have to find out.
Does anyone know if the rears fit the front? My guess is no but has anyone tried it? Thanks everyone
255 on the front work, but you'd need to plan on using spacers. I've read of both on here: some like the 225 squared, and others like the wider look squared.
On speedometer difference: that isn't in any way a function of a particular tire per se: it is OD changed from the OEM. If you use a wheel and tire combo that retains the OEM OD your speedometer will not change.
