Proberge4273
- May 15, 2024
Hi - Everyone,
I just had a set of NGT secondary downpipes installed a couple of days ago, and I'm noticing an issue with my Stinger that I'm not sure is related to the installation.
When I first got the car back, everything seemed to be running smoothly on the drive home. I stopped to fill up with 4 gallons of E85 and topped off with 93 for my hour-long drive back. The car continued to run smoothly after refueling, and I parked it for the night. The next day, I took it out to see if there were any performance gains with the new downpipes. However, I noticed that when pushing the car in Map 0 at high RPMS, it would hesitate and backfire a couple of times. Unfortunately, I wasn't able to capture any logs on JB4 when this happened.
I was suspecting bad gas or maybe too much E85, so I decided to run the tank down to half and refill with straight 93. Since refuling with 93, the backfiring and hesitation have stopped but now I've noticed another issue. The car is pulling timing by almost 4 degrees in map 0, whereas before the downpipe install it could run any map with only 0.8-degree of fluctuations in timing.
The spark plugs don't have many miles on them and were working perfectly fine before the installation. What could be causing this? I have attached a couple logs in each map if you guys could take a look.
