Taimaishoo
I would think spray is cheaper, though may look hit or miss in different areas, just like with any paint job, you may (or whoever does it) spray heavier in one area while lighter in another, etc. You may have to reapply or touch up with a spray, whereas wrap will be more durable. If you are just playing with different colors, definitely go with a spray as it is probably more easily removable than a wrap, I don't know for sure, but I would gather. If you wanted to change the colors of the rims, I would recommend sprays as temporary, you can tape up and probably get a cleaner look. For a permanent color change on the rims, I would recommend powder coating for better protection against chipping and pealing. They spray a plastic powder that is electrically charged so it is statically clings to to the metal, put it in a big oven and bake it so that the plastic powder melts and adheres to the metal, as well as color blending, glossy look, flat look, etc. They can do wonders mixing that powder to get damn near any color and/or mix of colors you want. Of course you have to take the tires off, give them the rims, put the tires back on, balance, etc, etc.
