Consequential
- Mar 5, 2018
Hi all,
I noticed that if you turn the heat on to max power and set it to blow out of the dash vents (as opposed to floor for example) the rear seat air vents hardly blow out any air. Now, if I turn the rear vent cold/hot vertical dial from full heat to full cold, the air flow is very powerful.
I'm actually at a dealship now getting the wheel alignment done (was bad from factory) and I tested a GT model as well as an Optima and both appeared to display the same behavior.
Can some of you please test your cars and comment?
Thanks!
Thanks!
