NorcalJohn
- Jan 24, 2018
Had a chance to take the stinger out for a track day with NASA. Ran it in group 3 and had a blast. Had the great fortune to experience dry, damp and pouring rain during our sessions and was very impressed with the car. Zero brake fade, overheating or mechanical issues and I pushed the car very hard thuought the weekend. I did quite a bit of prep work on the car but I think it would get around the track fine stock provided you change out our brake fluid to a high heat fluid. If you want a turn key setup that will most definitely work and have you running over M3s and Porsche products here is what I did:
-Eibach Prokit
- Front Camber -1.2
- Rear Camber -2.0
- Front 19x8.5 +35 245/35/19 R888R 40psi
- Rear 19x10 +42 245/35/19 R888R 40psi
-Stoptech STR-660 Brake Fluid.
-Eibach Prokit
- Front Camber -1.2
- Rear Camber -2.0
