For Sale Stinger Gt RWD Part Out
awake
Sacramento, CA
Stinger GT 3.3T RWD part out
Sold my Stinger and took most of the aftermarket parts off beforehand.
Prices are OBO. Smaller things I don't mind shipping at buyers expense, but big items might be a bit harder.
Located north of Sacramento, can meet up within reason.
-Ark catback exhaust - $800
-Eplus carbon fiber tips to fit the Ark - Will include with the exhaust unless someone wants them before that sells, then $20
-AEM Intakes (with the CARB sticker, so Ca legal) - $250
-Velossa Tech snorkels - $150
-Agency Power intercooler - $400
-SXTH EK1 Pro, will need to be reset (SXTH says it's $75 to do) - $400
-SXTH ECU stage 2 (came from the person I bought the EK1 from, it's a 93 tune and I'm in Ca, so never plugged it in and it is not VIN locked) - $350
-Lap3 ECU stage 1, will need to send to Lap3 - $350
-Lap3 TCU stage 2, H-matic (GT & GT1) - $1,000
-SXTH Single Oil Catch Can - $100
-New set of M45IL spark plugs - $150
-1 new coil (I bought as backup in case I broke the one under the plenum) - $20
-Covercraft custom fit window shade - $60
-Rear only - R1 Concepts geo-carbon rear brake rotors and R1 Optimum Oe rear pads - $100
-ProClip custom phone mount - $10 just the mount or $50 with the wireless charger
-TuxMats (for RWD) - $120
-Trunk/seatback protector - $10
-Megan Racing rear arm set (I checked they are 12mm like they should be) - $400
-Random rubber trim piece for under the hood - Free if it's one you need
Stock things not pictured (was too difficult to remove without a full lift):
-Stock front and rear sway bars - Free
-Stock secondary cats/downpipes - Free
Sold to CarMax, so if you want WhiteLine sways & endlinks or Ark downpipes that are still on the car, it's a 2019 GT with ~41k miles. Take it for a long test drive and swap them out.
View attachment 88937View attachment 88938
Hey there.
Interested in the SXTH Stage 2 ECU. Curious if you have a list of the settings it was setup with. And how do you know for sure it’s not VIN locked? Is it just plug and play then and becomes locked on first install? Is it an ECU for the base GT, or GT2? Not sure if there is a difference though.
Hey there.
Ordered it off John Hert, he was on a bunch of the FB pages. He never installed it, and neither did I. It is SXTH stage 2 with WMI tune. GT and GT2 are the same for ECU tunes, as long as it's the 3.3tt engine. Only different for TCU tunes as GT2 is e-shifter.
And the power cycling was fixed with a software update. Worked perfectly since then.
Forum won't let me edit the initial post for some reason.
*UPDATE*
-Ark catback exhaust - $800 SOLD
-Eplus carbon fiber tips to fit the Ark - Will include with the exhaust unless someone wants them before that sells, then $20 SOLD
-Agency Power intercooler - $400 SOLD
-Rear only - R1 Concepts geo-carbon rear brake rotors and R1 Optimum Oe rear pads - $100 SOLD
-TuxMats - $120
-Megan Racing rear arm set (I checked they are 12mm like they should be) - $400 PENDING
PM'ed you
*UPDATE*
-Lap3 ECU stage 1, will need to send to Lap3 - $350 SOLD
SOLD
-Velossa Tech snorkels - $150 SOLD
SOLD
-SXTH EK1 Pro, will need to be reset (SXTH says it's $75 to do) - $400 SOLD
-SXTH ECU stage 2 (came from the person I bought the EK1 from, it's a 93 tune and I'm in Ca, so never plugged it in and it is not VIN locked) - $350 SOLD
SOLD
-TuxMats - $120
SOLD
