Stillen exhaust does not fit 2022 model !
mikegt2
Bought Stillen exhaust after talked to dealer they talked to Stillen and said it would fit will does not fit they don't line with exhaust tips up at all, does anyone installed aftermarket catback on 2022 model and pipes line up i also purchased exhaust tips but need to find exhaust to fit the 2022 model .
That looks like it "fits" just fine to me. The whole point of the giant fake exhaust outlets is that the real exhaust pipes just float somewhere inside of there, and they shouldn't be visible. Maybe the 2022 exhaust dress tips are a spaced a smidgen further apart than earlier?
If you want the pipes to be perfectly centered then have that shop cut off the current extensions and make their own. Won't even take them an hour, probably not even half an hour.
Does that drone a ton?
2022 have bigger tips so makes sense that they dont align, its an easy fix for an exhaust shop though.
Will if other people like oddball think's "it fits just fine to me " then i guess go ahead and purchase, i wanted other stinger owners to know the fitment is not good does not center up at all had exhaust tips to put on to remove the stock tips but was way off center !
To be honest my MBRP exhaust doesn't line up completely centered also. That's after market parts, have to give a take.
the stillen exhaust is not line up at all both pipes touch inner tips needs to be about 2 more inches apart for the 2022 model.
I ended putting a Borla system on my 2022 and it does not align either, had to have my exhaust shop bend it and even then it’s not perfectly in the middle. Because of that I don’t think after market tips will ever work for me, but I had them extend it about 2 inches and I barely hear any drone. I am coming from a straight pipe system which was crazy loud so that might factor into it too
Yes they said they could bend it put didn't want to do that i will just wait and hopefully they will come out with something for the 2022 model .
Don't hold your breath!
Two minutes and a pry bar will solve the contact issue.
Will just wait tell manufacture has better fitting , already have ark midpipes so with it in sport mode sounds descent .
Are you noticing any significant power gains with this set up? I to have ark mids on a 22. Was looking into the Stillen system
Sent the Stillen back because did not line up with exhaust tips not even close.
I would have just had the shop go ahead and mod the mufflers to make the tips line up; it is a piece of cake for good shops.
If your using the factory hangers mod the mufflers won't help you would have to bend the pipes to make it fit then you would a kink in the piping.
Would have just ditched the factory tips. Those things are far too big for my tastes anyway
There are currently no exhaust options that are made specifically for the 2022 model because they will all have this
problem due to the spacing difference of the outlets in the new diffuser.
This a simple fix guys! All you have to do is support your bend application with padding and pull it out 1.75 inches on both sides horizontally. It’s really a Simple fix and I am getting ready to order the system for my 2022
I will be back up here shortly on the post to show you how to amend this issue
B, yes please let us know how it comes out and report back with pics to us and how you did it. I have my 2022 GT2 with the Borla and Ark Down Pipes on the car now so tips will be a nice addition once this is all sorted out. At highway speeds right now without tips it sounds amazing.
Curious if you posted your solution yet?
