I have the same feeling as the OP
I did change my brake fluid to a better one to try to achieve stiffer/more sensitive brake pedal .. while my car is almost 3 years old it did get better just a little bit but nothing really changed
tried performance brake pads (giro disc magic pads) but the brake feeling only got worse
I changed back to stock brembos as they bite nicer
now I understand that this soft pedal is normal on this car .. but I’m wondering if there’s a safe way to pump up the sensitivity just a little for that extra insurance feeling?
is adjusting the brake booster possible? is lengthening the pushrod on the brake booster just a tiny bit for that extra brake pedal stiffness without having the brakes being constantly engaged when not desired is a good idea?
what I and the OP are noticing is how the brakes are designed and not a malfunction.. so we are not trying to fix it, but only trying to adjust it to our liking
PS: my
G80 is gripping very hard on low speeds and that’s the opposite of my
G70
Although the
G70 have much stronger brakes especially on higher speeds
this confuses me when I switch between cars .. the brakes behave very different
And I like the brake feel on the
G80 more than on the
G70
Thankful for any helpful input on that
