Stinger GT SS
5000 Posts Club!
These may be of interest to some.
Yes, i had to bend mine a little, too. The biggest problem you'll have is finding the way to attach it to panel. Double sided tape doesn't work with that plastic Grill weekend (no steak involved)Mine don’t fit the curvature of the stock speaker “grill” completely. Was that the case with yours? I think the person on FB mentioned having to bend theirs a little to match the curvature. Hopefully if I can get the fit right, I might have some luck
Yea, let us know if you can find the way. It does look good. But for now, i am driving with just driver side grill (surprisingly is still holding)Uggh. I guess I’ll be doing some research this weekend. They look very good in that picture of your car. Definitely worth it to get this figured out.
Have you tried wiping around the plastic speaker grill perimeter with an alcohol wipe & also replace that double sided tape with 3M automotive tape should stick bettter.Yea, let us know if you can find the way. It does look good. But for now, i am driving with just driver side grill (surprisingly is still holding)
Yep. Cleaned it with alcohol. And tried two different tapes. Automotive extreme and gorila tape. Was thinking about using epoxy. But that will be too messy.Have you tried wiping around the plastic speaker grill perimeter with an alcohol wipe & also replace that double sided tape with 3M automotive tape should stick bettter.
I actually took the panel off the door, so i could lay it down.The guy on FB said he used alcohol to clean and a heat gun to warm everything up when someone asked about the grills popping off. I want something that I know for sure should work.
Oh bummer, yeah don’t use epoxy, not worth it. Have you had any interior finish applied to the car or do you use any silicone based spray/liquid ie: Armorall to the surfaces.Yep. Cleaned it with alcohol. And tried two different tapes. Automotive extreme and gorila tape. Was thinking about using epoxy. But that will be too messy.
Yes, i use some plastic cleaner/protector on it. But i think the alcohol removed it.Oh bummer, yeah don’t use epoxy, not worth it. Have you had any interior finish applied to the car or do you use any silicone based spray/liquid ie: Armorall to the surfaces.
You might have to give it a few wipes/clean over a couple of days to ensure it’s clean of any residue, also it’s not too cold is it.Yes, i use some plastic cleaner/protector on it. But i think the alcohol removed it.
